#1 2010-11-22 11:47
mf99
Reset serialized number on change of date
I have a vast photo collection that I would like to rename into the following format YYYY-MM-DD-xxx  where xxx is a serialized number that resets on change of photograph date.
I can achieve most of what I want with standard Delete, Insert and Serialize rules, but only with files from the same date.  I suspect a Script is required to reset the serialize number and that is where some help would be gratefully received as programming is not one of my strengths.
Many Thanks in advance.
#2 2010-11-22 12:34
Re: Reset serialized number on change of date
Hi mf, welcome to the community.
@Denis: maybe you want to think about adding this feature to the gui: "Serialize > [ ]Reset if file name change" ?
mf, you may try the following script with copies of your real files first.
I have tested this with an few test files only:
First add rules to get your wanted file name, but without the serialized counter:
For example my test names:
1) Delete: Delete last sign
2010-11-20-a    2010-11-20-
2010-11-20-b    2010-11-20-
2010-11-20-c    2010-11-20-
2010-11-20-d    2010-11-20-
2010-11-21-a    2010-11-21-
2010-11-21-b    2010-11-21-
2010-11-22-a    2010-11-22-
2010-11-22-b    2010-11-22-
2010-11-22-c    2010-11-22-
Warning: found 6 invalid file names!
But this warning doesn't matter since we gonna add an script to add serialize number which reset if file name change:
(Read our wiki how to use an script >> http://www.den4b.com/wiki/ReNamer:Rules:PascalScript )
//Add serialize number but reset counter if file name change
  CurrOrgFileName, LastOrgFileName, SerialString, LastOrgFileNameStorage: WideString;
  SerialNumber: Integer;
   LastOrgFileName := LastOrgFileNameStorage;
   CurrOrgFileName := WideExtractFileName(FileName);
   LastOrgFileNameStorage := CurrOrgFileName;
   //If FileName still the same then
   //increase SerialNumber, else reset to 1:
   If (CurrOrgFileName = LastOrgFileName) Then
             SerialNumber := SerialNumber+1
   else
             SerialNumber := 1;
   //Pad SerialNumber to wanted length:
   SerialString := IntToStr(SerialNumber);
   While (Length(SerialString) < 3) Do
              SerialString := '0'+ SerialString;
   FileName := CurrOrgFileName + SerialString
Result of this script:
2010-11-20-a    2010-11-20-001
2010-11-20-b    2010-11-20-002
2010-11-20-c    2010-11-20-003
2010-11-20-d    2010-11-20-004
2010-11-21-a    2010-11-21-001
2010-11-21-b    2010-11-21-002
2010-11-22-a    2010-11-22-001
2010-11-22-b    2010-11-22-002
2010-11-22-c    2010-11-22-003
HTH? big_smile
If yes, spread the word about ReNamer, help two others too and read my signature ;-)
#3 2010-11-22 16:16
mf99
Thank you very much Stefan.
I shall try this out tonight.
#4 2010-12-17 14:56
239
this feature is the reason why i registered here big_smile would be so nice to have it!
#5 2017-05-27 08:32
Option "Reset if file name changes" has been added to the Serialize rule in ReNamer v6.7.0.1 Beta.
#6 2017-10-27 08:12
Works perfect, many thanks for building in.
Q: Keep first part of name, and then serialize same named files afterwards:
A: USE:
1) Delete: Delete from Position 8 until the End (skip extension)
2) Serialize: Incremental from 1 step 1 repeat 1 (reset index if file name changes) and pad to length 2 as Suffix (skip extension)
