#1 2006-10-28 23:34
pstein
Column width+sizes not remembered / always switch back to initial size
Assume I add some files to Renamer, then adjust the column width of the Name and New name column. Finally I add a replace rule and click Preview
then the columns are re-adjusted to an initial width size.
Why not remembering the width size ?
For me it is much more important to see the target new name than the old one.
So I made the "New name" column much wider than the column with the original name.
#2 2006-10-29 00:07
Re: Column width+sizes not remembered / always switch back to initial size
Open Settings in the main menu, Preview tab: unmark option "Auto size table on change".
Also, right-click on the files table header to see a list of all available columns.
