#1 2014-11-19 03:49
traycerb
Bug: Countdown Status doesn't update in 1BY1 mode
Using portable Shutter Lite (v 3.6) on Win7x64, adding a Countdown event with 1BY1 logic, the status shows only "Time left: 0:00:00" after starting.  The action triggers at the correct time; only status doesn't update.  Let me know if you need a screenshot or further info on to reproducing this.
EDIT: It probably has the same origin, but the notification tray icon pop-up also reads  "Countdown Time left: 0:00:00".
#2 2014-11-19 21:27
Re: Bug: Countdown Status doesn't update in 1BY1 mode
There was a small problem with generation of the status message, only for timer events, only for the first event, only when 1BY1 logic is used.
Very well spotted, and thanks for reporting!
It should be fixed in latest development version:
http://www.den4b.com/?x=get&product=shutter&type=beta
#3 2014-11-20 19:21
traycerb
No problem, and thanks for the quick fix.  I'll be sure to check it out as soon as I can.
