#1 2015-10-21 03:21
dodol
Shutter + VMWare network usage
I'm curious why after upgrading to Vmware Workstation 11 or 12,
shutter unable to detect guest network usage ?
with VMware Workstation 10 shutter able to detect network usage just fine.
Is it shutter problem or VMware change something to their driver ?
Thank you
#2 2015-10-21 09:25
Re: Shutter + VMWare network usage
Are you selecting (monitoring) a correct network interface? Screenshot?
VMware adds a few virtual network interfaces, which would different traffic to your physical interface.
#3 2015-10-21 09:42
dodol
I delete everything except "host only" so I doubt I select the wrong network interface.
and reverting to vmware workstation 10 always work.
ss
#4 2015-10-22 00:21
Which versions of host and guest OS are you using?
Did you try any other simple network usage monitors?
