#1 2016-08-07 06:45
skylinekiller
rename seasons S##E## to show s##e##
How can i change the caps for the seasons and episodes only?
#2 2016-08-07 09:54
Re: rename seasons S##E## to show s##e##
The easiest way to do this is with a RegEx rule:
Replace expression "\bS(\d+)E(\d+)\b" with "s$1e$2" (skip extension)
#3 2016-08-07 12:14
skylinekiller
Thank you, I will give it a go.
#4 2017-10-25 14:38
Krycek
Hi there.
I want to do something similar.
File name: Robot Chicken - 07x01 - G.I. jogurt.web-dl.english.c.edit.addic7ed.com.srt
Change like this: Robot.Chicken.S07E01.G.I..jogurt.WEB-DL.srt
First:
Find: - 07x * | * * | * .- * * | * _
Replace: S07E * | *. * | *. * | *.
Than:
Delete: Delimiter >>>. English till the end.
It happens this way. No problem.
In the first step I want to keep the season and episode numbers constant. Is this possible? For example, when applying this rule to Season 6 files, I can use it without making any other changes to the rule.
---Google Translate---
#5 2017-10-26 03:00
This is the rule set that i would use in your case:
1) Replace: Replace all " - " with ".", " " with "." (skip extension)
2) Delete: Delete from Delimiter "web-dl" until the End (leave delimiter) (skip extension)
3) Regular Expressions: Replace expression "(\d\d)x(\d\d)" with "S$1E$2" (skip extension)
If have an input filename:
The rules above will produce:
Robot.Chicken.S07E01.G.I..jogurt.web-dl.srt
