#1 2016-10-03 01:58
kunkel321
Settings not remembered in Win 10?
Sorry, in advance...  This is bound to be a dumb question.
Why am I getting this "first launch" dialog every time I launch ReNamer?
screenshot
Also, I'm not seeing my saved presets.  My laptop was recently reimaged with Windows 10 (changed from Win 7).  I ReInstalled ReNamer from scratch...  Or at least I think I did(?)  Interestingly, my registration info *is* remembered.  But apparently ReNamer does not remember that it's been launched before.
Any ideas?
#2 2016-10-03 07:41
Re: Settings not remembered in Win 10?
These questions should should help us figure out what's happening:
  1. Which version of ReNamer are you using?
  2. Which version of Windows were you using before upgrading to Windows 10?
  3. Open Presets > Manage from the main menu, which path is displayed in that dialog?
  4. What is the full path of ReNamer.exe (i.e. where is it installed)?
  5. Do you see a file Storage.ini in the same folder as ReNamer.exe?
  6. Open file Storage.ini with Notepad and paste here its content.
Also, check if you find your presets in the VirtualStore location.
