I've a lot of MP3s that I've ripped from mix CDs in the following format:
01 - Artist - Track - Mix.mp3
They are mixed in with tracks in the following format:
02 - Artist - Track.mp3
Is it possible to write an expression that would rename the first to:
01 - Artist - Track (Mix).mp3
But leave the second file alone?
Any help most appreciated.
How do you determine which "-" to replace with "(" ?
Is it always the 3rd or later occurrence of "-", or whichever one as long as it ends with "Mix"?
More examples might help too.
Hi
I suppose to cover artists who may have - in the name it would be as follows:
If there is more than one "-<space>" then replace the right-most one with "(" then terminate the filename with a ")"
I can gather some real examples in the morning - thanks for the help (and an awesome program)
I presume you meant if there is more than two "-<space>", otherwise even "02 - Artist - Track.mp3" will get replaced.
So, here is a RegEx rule:
Replace expression "\A(.*)\s+-\s+(.*)\s+-\s+(.*)\s+-\s+(.*)\Z" with "$1 - $2 - $3 ($4)" (skip extension)
Input:
00 - Artist.mp3
01 - Artist - Track.mp3
02 - Artist - Track - Mix.mp3
03 - Artist - Track - Track - Mix.mp3
04 - Artist - Track - Track - Track - Mix.mp3
Output:
00 - Artist.mp3
02 - Artist - Track (Mix).mp3
03 - Artist - Track - Track (Mix).mp3
04 - Artist - Track - Track - Track (Mix).mp3
That worked perfectly - thanks very much!
