Hi Folks.
Given a set of names like:
Scientific American Mind Volume 27 issue 6 2016 [doi 10.1038%2Fscientificamericanmind1116-10b] Knight, Meredith -- Weight-Loss Surgery Alters the Brain.pdf
Scientific American Mind Volume 27 issue 6 2016 [doi 10.1038%2Fscientificamericanmind1116-25] Steinberg, Louisa J. -- Sleep No More.pdf
Scientific American Mind Volume 27 issue 6 2016 [doi 10.1038%2Fscientificamericanmind1116-38] Cooperrider, Kensy; Núñez, Rafael -- How We Make Sense of Time.pdf
Scientific American Mind Volume 27 issue 6 2016 [doi 10.1038%2Fscientificamericanmind1116-58] Bangasser, Debra A. -- Stress.pdf
I'd like them changed to:
MIND -- Weight-Loss Surgery Alters the Brain (Knight, Meredith, 2016).pdf
MIND -- Sleep No More (Steinberg, Louisa J., 2016).pdf
and so on...
I'm using RegexBuddy with PRCE definitions, and it does indicate that this regex
(Scientific American Mind Volume [0-9]* issue [0-9]* )(2016)( \[\N*\] )(\N*)( -- )(\N*)
Does match the 4 samples above.
I don't think ReNamer recognizes it as proper syntax though...
I'm only a beginner with regex, and I'm not a programmer. But my thought is to capture these groups
1(Scientific American Mind Volume [0-9]* issue [0-9]* )
2(2016)
3( \[\N*\] )
4(\N*)
5( -- )
6(\N*)
And rearrange (some of) them like this:
MIND -- $6 \($3, $2\)
(I just realized that I have the literal "2016" in there, but I'll fix that later.)
Thoughts?
Scientific American Mind Volume 27 issue 6 2016 [doi 10.1038-10b] Knight, Meredith -- Weight-Loss Surgery Alters the Brain.pdf
Scientific American Mind Volume 27 issue 6 2016 [doi 10.1038-25] Steinberg, Louisa J. -- Sleep No More.pdf
Scientific American Mind Volume 27 issue 6 2016 [doi 10.1038-38] Cooperrider, Kensy; Núñez, Rafael -- How We Make Sense of Time.pdf
Scientific American Mind Volume 27 issue 6 2016 [doi 10.1038%2-58] Bangasser, Debra A. -- Stress.pdf
MIND -- How We Make Sense of Time (Cooperrider, Kensy; Núñez, Rafael, 2016).pdf
MIND -- Stress (Bangasser, Debra A., 2016).pdf
RULE:
Match the year of the 'issue 6 2016' part as $1
Match everything between ']' and '--' as $2
Match all from '-- ' till the end as $3
USE:
RegEx rule
Expression: ^.+issue \d+ (\d\d\d\d) .+] (.+) (--.+)$
Replace: MIND $3 ($2, $1)
[x]Skip extension
HTH?
Explanation:
^ >> anchor start of string
.+ >> match one-or-more of everything, till
issue \d+ >> match 'issue' followed by one-or-more digits, till
(\d\d\d\d) >> match four digits as year, store as $1
" .+] " >> match space, one-or-more of everything, closing bracket (reg ex meta sign, but single closing one, so fine)
(.+) >> match one-or-more of everything between ']' and ' --', store as $2
(--.+)$ >> match '--' and the rest till the end, store as $3.
Far out ... That's quite different from mine. Many Thanks Stefan!
As it turns out, my name is also Stefan. Well... "Stephen" actually.
Additional question: Is this a "Pascal flavor" of RegEx? I also see that a Delphi tool is mentioned at the bottom of the help docs...
The free TRegExpr library is used here. (Same as with TotalCmd)
Which, in turn, use a "normal / default" Perl -like syntax.
More information:
http://regexpstudio.com/TRegExpr/TRegExpr.html
http://regexpstudio.com/TRegExpr/Help/r … yntax.html
