#1 2017-01-25 09:29
bitseeker
How to see which rows are affected by rules
Hi there,
renaming a long list of files:
Is there a way to see which files (rows) are affected by the rules, when previewing?
I noticed that you can´t differ between affected and not affected rows by the rules, but would be great when checking if my rules work the way i expect. Right now i have to check every single row - which is very time consuming when dealing with way over 100 rows.
e.g. changing background color of rows would help enormously
thx
#2 2017-01-25 10:12
bitseeker
Re: How to see which rows are affected by rules
Nevermind, just found it under settings>preview
PS. you might want to delete this post - go ahead wink
#3 2017-01-25 14:32
Good, you found it!
In case someone else is looking for that option, it is under Settings > Preview > Highlight changed filenames.
#4 2017-01-25 14:45
bitseeker
would be awesome, if the number of the affected rows/files would be shown in the status bar.
You already show the number of loaded files, so maybe like this:
