Using ver 6.6 pro:
e.g.
i have 84 files loaded and i can see that 15 files would be affected by the rule(s) by being highlighted in different color (settings>preview>highlight changed file names).
Then applying the rules, the message popup says: "84 file(s) successfully renamed."
That is confusing, cause there were only 15 renamed.
Shouldn´t it say "15 file(s) successfully renamed." ???
greets
Every marked file in the table will be renamed, that is just how ReNamer works.
However, it is planned to add an option to skip renaming of unchanged files, which will avoid a sometimes confusing message.
This option has been added in ReNamer 6.6.0.6 Beta.
