When you have multiple things you want to find & replace, you can click the + button to add each item. I was wondering if there's a keyboard shortcut for the + button? I saw in the wiki that you can type *|* instead of clicking, but I was hoping for a Ctrl+N (or whatever).
You mean for "Add Rule"?
The hotkey is the INS-key.
(Right click the Rule pane to see all available hotkeys)
Also, you can just click into the Rule pane to open the Add Rule dialog.
Is it that?
EDIT: ahh, you mean the plus button in the Replace Rule-dialog itself.
No, there is no hotkey right now, me think.
I on my own would just type that '*|*' one time, then copy it and insert if need, but lets see what Denis says.
(Also I use for years "CLCL" as clipboard manager (old,free,portable) to be able to insert older clipboard items too)
There is no shortcut for inserting *|* separator.
However, you can use clipboard to speed up insertion.
I ended up using copy/paste. Thanks!
