#1 2017-03-31 17:02
fred
Font problem in high DPI
hello,
I have some issue with big size font see picture
problem font
thanks for your soft
#2 2017-03-31 17:14
Re: Font problem in high DPI
This is a known issue and it will be addressed in future versions.
ReNamer does not scale well with extremely high DPI settings. The spacing and containers do not get adjusted accordingly to fit the massively increased text.
In the meantime, you can either decrease your DPI settings or run ReNamer with compatibility settings, as explained here:
https://support.microsoft.com/en-ie/hel … compatible
#3 2017-03-31 17:38
fred
thanks for your help
best regards
fred
#4 2017-11-10 12:17
Shaipetit
I'm using Windows 7 with 200% DPI scaling and some ReNamer elements are cut:
Windows 7 200% DPI scaling
If compatibility settings are applied for ReNamer, then other GUI issues emerge:
Compatibility mode
Thank you.
#5 2017-11-20 08:59
Thank you for reporting this issue.
It is a known problem. This will be fixed once ReNamer is migrated to a newer development environment, which is planned for near future.
