#1 2017-07-13 23:20
Stamimail
Change the order of options in Serialize rule
Consider to put "Repeat:" above "Step:".
#2 2017-08-08 22:20
Re: Change the order of options in Serialize rule
Why?
#3 2017-08-08 23:16
Stamimail
I can't remember exactly now.
This what was my experience while using.
I think it was to avoid possible misunderstandings.
Maybe the difference between Repeat and Reset every
Maybe to avoid the thinking Repeat relates to Step
#4 2017-08-08 23:22
I agree that the changed order seems more natural, but I also fail to explain exactly why, that is why I asked.
The order of those options will be changed for the next version.
