#1 2017-09-19 09:01
skravchuk
Rename files with duplicates
Hi I have 1095 files from 1 to 1095 (1.png)
I need rename all files  like:
set1-1
set1-2
set1-3
set2-1
set2-2
set2-3
set3-1
set3-2
set3-3
etc...
Print screen
#2 2017-09-19 09:20
Re: Rename files with duplicates
Try this 5 Rules/steps (ignore the warnings till step 5 will clear it all):
1) Delete: Delete from Position 1 until the End (skip extension) -> delete the old name.
2) Insert: Insert "set" as Prefix (skip extension) -> you can skip step 1) if you use here "replacing current name" in newer ReNamer versions.
3) Serialize: Serialize Incremental from 1 step 1 repeat 3 as Suffix (before extension)
4) Insert: Insert "-" as Suffix (skip extension)
5) Serialize: Serialize Incremental from 1 step 1 repeat 1 (reset index every 3 files) as Suffix (before extension)
#3 2017-09-20 15:17
Reported Yesterday 10:43:03
Reported by skravchuk
ReNamer » Rename files with duplicates » Post #10093
Reason: Thank you so much Stefan. All good, you the best !!!
#4 2017-09-20 23:20
