My current renaming app cannot do what i want so i'm on the lookout for something new.
If for example i had a tv show called the following
"It's Me - S01E00 - Pilot"
"It's Me - S01E01 - At The Start"
"It's Me - S01E02 - On Our Hols"
etc etc can this app remove everything after the episode numbers so it would look like this:
"It's Me - S01E00"
"It's Me - S01E01"
"It's Me - S01E02"
Hi and welcome.
Try that...
It's Me - S01E00 - Pilot.ext
It's Me - S01E00.ext
Rule in plain English:
Match [everything] till [space hyphen space] followed by an 'S', two digits, an 'E', two digits, drop the rest.
ReNamer RegEx Rule
Express: ^(.+ - S\d\dE\d\d).+$
Replace: $1
Read too
http://www.den4b.com/wiki/ReNamer:Rules:RegEx
HTH?
Alternatively, you can also use a Delete rule:
Until: Delimiter " - "
Right-to-left: YES
Skip extension: YES
This will remove everything from the last occurrence of " - " until the end of the filename.
OK this is great Den4b option looks the easyoption so i'll download the trial version and give it a go many thanks.
