#1 2018-11-06 01:50
cj283
Preset File Location
Does anyone know where the Renamer preset file is located. Is it possible make a backup prior to a windows reinstall?
According to the preset manager the files should be in C:\Program Files(x86)\ReNamer\Presets\ , but this folder doesn't exist...
#2 2018-11-06 02:43
Re: Preset File Location
It appears that you are using a significantly older version of ReNamer, prior to v6.
In this case, your presets are probably located in the VirtualStore folder, which would map into something like this:
C:\Users\<USERNAME>\AppData\Local\VirtualStore\Program Files (x86)\ReNamer\Presets\
See here for more details: ReNamer:Using_presets#VirtualStore
#3 2018-11-06 07:57
cj283
Perfect. Found them! Thank you.
