#1 2020-01-05 17:07
ReiM
ReNamer includes new format "HEIC"?
In the last months I used the EXIF-Date to renamed my private pictures with "ReNamer". Now I notice the format HEIC in my lists of pictures.
- Are there any plans to include this format, too?
- Are there a workaround for my problem?
Thanks for information or support.
#2 2020-01-06 12:33
Re: ReNamer includes new format "HEIC"?
There is no built-in support for HEIC / HEIF image file format yet, but you can use a 3rd party tool such as ExifTool in combination with ReNamer to extract meta tags and then use them for renaming files.
See the example script:
https://www.den4b.com/wiki/ReNamer:Scripts:ExifTool
#3 2020-01-06 23:20
ReiM
Thanks for your reply. I will try it in the next days and will come back with my experience.
#4 2020-01-08 06:29
Andrew-HOD
Please build-in support for HEIC/HEIF image file format.  The main use I have for this program is renaming poorly named images.  The iPhone and even now Canon (CES, EOS-1D X Mark III SLR) will be supporting this format.  Exiftool is so SLOW and difficult to work with.
#5 2022-02-04 23:38
AndrewRH
The script works for me - thanks! However it is very slow to process a directory full of files.
Is there a plan to have HEIC/HEIF image info supported in Renamer Pro? If so, then when might a first version be available?
Thank you.
#6 2022-02-21 18:07
There is no plan for a direct support for HEIC/HEIF images in ReNamer. Unless someone can find or donate a Pascal compatible source/library that offers such support.
However, there is a long term plan to make the use of 3rd party tools/libraries much easier, either via a dedicated renaming rule or via a plug-in based meta tags framework.
