#1 2020-05-04 19:47
yvoictra
Can't get META TAGS from DNG files
Hello support,
I am trying to insert the META TAG "EXIF_Date" as a prefix in a filename, but it seems with DNG files from my Pixel 2 XL it doesn't work.
Renamer doesn't insert the META TAG:
renamer
However, Windows in the properties of the file, seems to have this information:
properties
Could you help me?
Thanks!
#2 2020-05-05 08:40
Re: Can't get META TAGS from DNG files
DNG images are not supported out of the box, but you can use the Pascal Script rule to integrate 3rd party tools which can extract meta tags from DNG and many other image formats.
For example, see how to use ExifTool and Exiv2 tools in ReNamer:
http://www.den4b.com/wiki/ReNamer:Scripts:ExifTool
http://www.den4b.com/wiki/ReNamer:Scripts:Exiv2
#3 2020-05-05 08:54
yvoictra
Thank you very much!
Best Regards.
