#1 2020-11-11 21:32
Rnmr
Matching a 'Particular' Space, with more than what is available
In Advanced Renamer program there is an 'instance' dropdown menu that expands beyond just 'all', 'first', and 'last'.
It includes 'all, first, 2nd - 7th, and last'.
Renamer does not have that. I'm guessing there is an easy way to do it directly with RegEx.
So, I want to replace a particular space (with more than available rule options) as ' - '.
How do I find 'space 3 or space 5 or 9, and so on' depending on the need of a particular filename?
- RWE
#2 2020-11-11 23:10
Re: Matching a 'Particular' Space, with more than what is available
Rnmr wrote:
there is an 'instance' dropdown menu that expands beyond just 'all', 'first', and 'last'. It includes 'all, first, 2nd - 7th, and last'.
It sounds like a useful feature.
Yes, this can be done with the Regular Expressions.
Replace 3rd space:
Expression: \A(.*?\s.*?\s.*?)\s(.*)\Z
Replace: $1 - $2
Input: 1 2 3 4 5 6 7 8 9
Output: 1 2 3 - 4 5 6 7 8 9
Replace 5th space:
Expression: \A(.*?\s.*?\s.*?\s.*?\s.*?)\s(.*)\Z
Replace: $1 - $2
Output: 1 2 3 4 5 - 6 7 8 9
#3 2020-11-12 00:28
Rnmr
Ok, thanks!
I was hioping for something where it is just one regex and part of it could be altered/replaced for the particular
space when needed (rather than altered by repetitive tack-ons).
I figured out how to do it with Rearrange rule that has 'around' the same degree of efficiency.
Replace 3rd space:
Exact Pattern of Delimeters: ' | | |'
New Pattern: $1 $2 $3 - $4
Replace 5th space:
Exact Pattern of Delimeters: ' | | | | |'
New Pattern: $1 $2 $3 $4 $5 - $6
It would be nice if something like that menu could be implemented.
I have some filenames with music artists/groups at the beginning. They just run into the following words/descriptors
without any division, and obviously the artist/group names will vary in length.
Thanks again!
- RWE
#4 2020-11-13 21:53
Rnmr
FYI:
Just a hasty oversight I'm sure, but your '5th space example' only matches up to the 4th space, thus only splitting at the 4th space location.
- RWE
#5 2020-11-14 13:16
Hmm, it works as intended for me.
Can you demonstrate how it doesn't work for you?
