#1 2021-02-09 17:39
ariah
How can I move files to a folder upwards in the file tree?
I love the ability to create subfolders using functions like Rearrange, but how would I move a file or folder to a HIGHER folder in the directory tree?
For instance, I have this:
C:\files\unique folder 1020\subfolder\targetfolder\
How would I move that to this, the same directory as its current subfolder?
C:\files\unique folder 1020\targetfolder\
I have a large number of unique folders, and some have the target folder, and some do not.
#2 2021-02-09 17:50
Re: How can I move files to a folder upwards in the file tree?
You can insert either an absolute or a relative path into the new name, and both will be resolved appropriately.
To move things up the directory hierarchy in a relative fashion, simply prefix your names with "..\" or several times that for each directory level.
See also: ReNamer:Renaming_to_another_folder.
#3 2021-02-09 18:44
ariah
Thank you!
I hope you don't mind if I ask another related question in the same thread.
Part of what I'm trying to do is move files and folders that begin with exactly four digits. If I use [0-9][0-9][0-9][0-9] as a mask, it just identifies anything that begins with a number, and disregards the number of digits. What is the proper mask for that? Is it possible?
#4 2021-02-10 00:11
Where exactly are you using this mask? In a rule or the filter settings or somewhere else?
You could do this with a single Regular Expressions rule, with the following rule configuration:
> Replace expression "\A(\d{4})\b" with "..\\$1" (skip extension)
#5 2021-02-10 03:26
ariah
That worked perfectly, thank you! I think I will use RegEx more often.
I was trying to use that [0-9][0-9][0-9][0-9] pattern in Rearrange and Replace rules.
