#1 2021-05-24 14:35
thiddleston530@gmail.com
Cannot see shutter at all now
I set shutter to automatically minimize when it starts, but not even an icon shows up in my tray? (I did set it to show a tray icon, and it does not) How do i fix this or view shutter to fix this? I tried Uninstall and reinstall, still same settings. Help please.
#2 2021-05-24 23:03
eR@SeR
Re: Cannot see shutter at all now
Try to edit or remove Settings.ini file in "Documents\den4b\Shutter" location. You might ticked "Never show Tray Icon" in Advanced tab. You can check corresponding wiki page for more information on how to fix it.
Denis, "Shutter.ini" is changed to "Settings.ini". "Never show Tray Icon" section, can be updated smile
#3 2021-07-30 06:33
Updated. Thanks for pointing it out!
See https://www.den4b.com/wiki/Shutter:Options#Advanced
