#1 2021-09-05 13:57
loungebob
Organize Rules in Folders or Clusters
I was unable to find something on this but maybe I used the wrong search key words.
I have 400+ rules in one of my presets and I was wondering why I cant put rules in folders to properly organize them?
It would save me so much time to a) be able to disable or enable a whole set of rules with one click (disable/enable rules in folder) and b) I wouldn't have to go through irrelevant rules to figure out where something goes wrong.
Also, it would help my OCD not having to look at that many rules :-)
And yes, if I was better at regex or pascal, about 250 of them would be unnecessary. But I'm not so...
And no, I don't want to spin-off rules into different presets.
#2 2021-09-05 22:28
Re: Organize Rules in Folders or Clusters
This sounds good. It has been added to the feature todo list.
However, we will probably see a different approach implemented first, that is a special kind of renaming rule which will allow users to use existing presets as individual rules. This should also help with organizing and reusing large collections of rules and presets.
#3 2021-09-07 03:08
loungebob
Dont quite understand what that means or how it will work but looking forward to it!
