#1 2022-04-06 20:02
tplatero
Feature request: Execution step by step
For debugging purpose it would be very useful to be able to execute the instructions step by step instead of having to delete and paste them one by one.
There are cases where I have more than 50 lines of instructions (with 40 lines of regex) and I have not taken into account something in the renaming and debugging is a nightmare.
#2 2022-04-06 23:58
Re: Feature request: Execution step by step
You can toggle (disable/enable) renaming rules via the checkbox located beside each rule.
You can also select multiple rules and toggle them at once.
#3 2022-04-07 11:36
tplatero
You are right. Sorry to have wasted your time.
