#1 2008-10-25 14:19
macantoso
CPU peaks
hello den,
i'am trying your latest beta version of shutter. I have a serious problem sending my pc to standby/sleep mode. Shutter maybe could solve it.
Windows Powermanagement can not sent the pc to sleep because it detects activity.
Scenario:
Events
User inactive for 5 Minutes AND
CPU under 10 % for 5 Minues (300 secs.)
The CPU < 10 % is interrupted for 1-2 Seconds in an intervall of 90 secondes. This caused to cpu ilde timer of shutter to reset. This is correct. But my system will never go to sleep wink
Question is: would it be possible to add an option the the CPU Usage Event that will reset the cpu idle counter only if the cpu has a load higher than the defined usage (here eg. 10 %) for a specific amount of seconds?
Example:
10 % Usage
3 Seconds duration (new option)
This would reset the cpu idle counter only if the cpu uses more of 10 % resources for minumum of 3 secondes. If the peak is shorter as 3 seconds it will be ignored and the cpu usage count still raises up.
Here is screenshot with the computer in "idle" mode and the peaks to be ignored:
Cheers, Mercantoso
big_smile
#2 2008-10-26 12:45
macantoso
Re: CPU peaks
Had an Idea for an alternative solution of my smile specific problem.
Shutter could/ should deny to shutdown if music or video is played by the system.
Cheers Macantoso
