#1 2009-08-26 08:11
Yearling
Shutter as a service
Hi, I use Shutter - it's a wonderful application and works very good but I need to use it as a service (WIN XP).
I tried to run it by the help srvany.exe (http://support.microsoft.com/default.as … -us;137890) - it is OK - Shutter is running as a service but it is impossible to use it in mode "go to sleep after user inactivity" - after adjusted time PC go to the sleep mode but independently of key pressing, mouse clicking, etc. - it is impossible to clear countdown by the key pressing, mouse clicking etc. - countdown is still running regardless of mouse clicking, key presing,...
Exist any different solution of this problem or would it be possible to solve this problem in next version?
#2 2009-08-31 21:41
krtek
Re: Shutter as a service
There is no easy way, but maybe this will help you: Shutter Wiki: Run as service.
#3 2009-09-01 09:48
Yearling
Yes I tried the first way (Windows tool - srvany + instsrv) - it is possible to install Shutter as a service, run Shutter as a service but Shutter as a service doesn't work good - it is impossible to use it in mode "go to sleep after user inactivity" - after adjusted time PC go to the sleep mode but independently of key pressing, mouse clicking, etc. - it is impossible to clear countdown by the key pressing, mouse clicking etc. - countdown is still running regardless of mouse clicking, key presing,...
#4 2009-09-06 21:37
There is an option to allow (or not) the service to interact with the desktop. Did you trying playing with it?
I have never tried running Shutter as a service, and it is not officially supported (as mentioned in the wiki article).
#5 2009-09-14 12:45
Yearling
Yes, I tried it but with the same results  sad
