#1 2006-07-22 01:00
ReNamer 4.10
This release contains many fixes and improvements, mainly for PascalScript rule and the Unicode support.
What's New:
* Added checkboxes for rules, to enable/disable rules without deleting them;
* Files that are not marked will not be validated, previewed or renamed;
* Fixed not synchronized states for files table and files objects on rename;
* Fixed incorrect validation when absolute paths are used in new names;
* Fixed incorrect capitalization of letters infront apostrophe in the words;
* Fixed waiting cursor and memory leak on exception in the preview process;
* Added skip extension and case sensitive options to Replace and Remove rules;
* Added mark by mask option to the context menu of the files table;
* Added WideGetChar function, workaround for a bug in the PascalScript which
  doesn't let access characters of a WideString by their index, e.g. WideString[I];
* Added WideLength, WideSetLength, WideCopy, WideDelete, WideInsert,
  WidePos and WidePosEx functions to correctly treat WideStrings;
* Added WideSplitString function to split string into an array of strings;
* Added WideScanDir function to scan directory for files
* Updated many other PascalScript Unicode functions;
* Updated help file for the Regular Expressions rule;
