#1 2009-05-04 01:00
ReNamer 5.50 and other news
It has been several months since I made a new release, but this is not because the work has stopped. In fact, just from the list of changes in ReNamer you can see quite the opposite. I have been working on 3 different tools for past several months: ReNamer, Shutter v3, and Hasher v3. ReNamer got a large number of updates, Shutter got completely redesigned and is almost ready for the release, and Hasher has been redesigned almost twice and now is getting to a very early Alpha stage with still a lot of work to be done.
There are also some activities aside from the main development stream. Narayan, with a help of few other users, is working on an extensive user manual for ReNamer. It would be really helpful if people could have a quick look, proofread it, and post their comments in the related topic: Making of new manual.
Also, myself and eR@SeR (Nikola) are trying to figure out a formal procedure for localization, so anybody could do it from their own computer without the use of expensive localization tools. Hopefully, soon we will publish a guide on the forum on how to localize (translate) some of my tools to any language.
I have to thank some of you who are helping me out, especially Narayan and eR@SeR for their will to help first of all, and for their work mentioned above. Thanks to all active members on the forum too, I am glad that some of you are able to help me out with it.
What's New in ReNamer 5.50:
* Updated PascalScript component to the latest SVN from 11 November 2008;
* Updated Virtual Treeview component to v4.7.0;
* Updated hashing functions to use Fundamentals Hashing unit v3.06;
* Reset Unicode flag for the manual filename editor in the files table;
* Added date-time offset functions: IncDay, IncHour, IncMinute, IncSecond, etc;
* Updated binary signatures for FLV/SWF and MP3 files;
* Added 24 new binary signatures, making a total of 93 records;
* Removed error message when applying extension detection rule in analyze dialog;
* Showing of non-main forms always centered is made optional;
* Changed format of Audio_Duration tag from "Xm Xs" to "X.XX";
* AVI and HASH tags can be read from Unicode filenames;
* Add 2 AVI helper tags: AVI_Duration and AVI_WidthAndHeight;
* Added 4 Meta tags for Outlook Messages: ID, DateSent, Subject, Sender;
* Added ShellOpenFile() function to open files via ShellExecute API;
* Another type of apostrophe is added to Case rule: Acute Accent 0x00B4;
* Fixed incorrectly adjusted time zone by the Email_DateSent tag;
* Fragments in the Case rule are replaced as Whole Words only;
* Delimiter for fragments is changed from space to comma;
* Speeded up generation of random numbers in Serialize rule;
* Unnecessary fields are automatically disabled in Serialize rule;
* Translit Alphabets will handle UTF-8 BOM correctly;
* Tab characters in PascalScript statements are replaced with spaces;
* Added "Insert after the current name" option to UserInput rule;
* Text in "Go To Line" dialog is added to resource strings;
* Improved exception handling for several dialogs;
* Updated French and added Bulgarian translit file;
* Analyze dialog now has line number and position from left and right;
* Corrected behaviour of "No" action in the meta tags confirmation dialog;
* Correctly handle renaming when user adds trailing path delimiters to new name;
* Added "Files" button above files table which brings up its popup menu;
* Auto preview on change of rules will not trigger on change of unmarked rules;
* All relative "." and ".." directories within new path are resolved;
* Added "-" (hyphen) to the CleanUp rule;
* Corrected ambiguous Kb/Mb/Gb to KB/MB/GB;
* Enhanced main icon using vector graphics;
* Rearranged file menus and options;
* Core code optimizations and cleanup;
* Corrected few typos;
