I can understood if this suggestion is from minor interest,
and you didn't want to spend that time for that,
but i want to make it easier for time-to-time users.
Issue:
I have this: "Filename.ext"
I want to add an serialized number at the end and have that number in brackets: "Filename (001).ext"
I have to add this rules: (as newbie i can't do scripting)
1) Insert: Insert " (" as Suffix (skip extension)
2) Serialize: Serialize Incremental from 1 step 1 as suffix (before extension)
3) Insert: Insert ")" as Suffix (skip extension)
So i want to ask for an improvement of serialze rule, I imagine two possibilities:
Possibility A.)
Add an option to the serialze rule like:
(o) Surround numbers by [ () ]
So we could just do:
1) Serialize: Serialize Incremental from 1 step 1 as suffix (before extension), surround by "()"
Possibility B.)
Just allow negative value for the "Insert where > Position: [ -1]", same as for Incr. Step value,
so the number is inserted at the second right position.
So we could use:
1) Insert: Insert " ()" as Suffix (skip extension)
2) Serialize: Serialize Incremental from 1 step 1 at position -1 (before extension)
I like possibility B, because then we can specify any characters we want, and not necessarily only "()". With A if someone wanted to use "[]" instead, then that would need to be accommodated, and so on. But with B that's not an issue since the insertion is a separate step.
Thanks.
I too think possibility B fits the best to ReNamer concept...
but possibility A was meant to implement an InputBox "(o) Surround numbers by [ ]" of course
While possibility B fits better to ReNamer, i think possibility A fits better to aid "once in a while" users.
Or just as in other places in renamer, the check box with "right-to-left" on the serialize?
