#1 2010-11-27 13:28
NexusIV
Replace some ".dot"
and...Renamer is a excellent software that I use for a long time.
I have a little question and I hope that someone can help me. I have similar files:
"xyz.name.2surname.v1.0.2.txt" (where v1.0.2 is the versionfile)
I would be rename this file so:
"xyz name 2surname v1.0.2.txt"
It's possible replace all the ".dots" of the file, but not replace the ".dots" of the versionfile? (after the char "v")
Thanks in advance
NexusIV
#2 2010-11-27 14:07
Re: Replace some ".dot"
Hi NexusIV, welcome.
Sorry, i have not much time right now, so here in short:
To replace all dots by spaces try the CleanUp-Rule.
You can also use the Replace-Rule (and some others too.
The trick is always to use "[X] Skip Extensions".
#3 2010-11-27 22:41
NexusIV
Yes !!!!
With "CleanUP" I have solved my problem.
Thanks Stefan
NexusIV
