I am trying to extract the exif date from a image file using pascalscript or other alternatives that is available for use in Renamer. Does anyone happen to have written such a script?
Do check out the Wiki etc. for help.
I manage to extract the exif date and rename the file with pascal script. The script is as below:
DateTime: TDateTime;
DateTime := FileTimeModified(FilePath);
FileName := WideExtractBaseName(FileName) +
' (' + CalculateMetaTag(FilePath, 'EXIF_Date') +
')' + WideExtractFileExt(FileName);
However, the extracted exif date is in the format of (yyyy-dd-mm hh.mm.ss). Is there any to reformat it again to ddmmyyyy or even better dd Jan yyyy
Here you have
