I am running the Beta Version of Renamer because of the Rearrange function that was added. I have several thousand audio files that I would like to swap the Title and Artist on. I'm able to get that to happen for the most part using Split By Delimiters (set as a "-) which is correct and patterns as $2 - $1. So far so good. But, all of the files have additional information after the title and artist.
For example:
Bobby Darin - Splish Splash [0-0-27-2].mp3
The information in the brackets is used for some automaton software I use. It needs to be there. Can I set renamer to avoid moving that information while still swapping out the title and artist?
The result I'm looking for is: (for example)
Splish Splash - Bobby Darin [0-0-27-2].mp3
Your help is appreciated.
Hi milwaukeeguy, welcome.
With the Rearrange Rule you can use more then one delimiter at the same time. Separate them by an "|"
For each delimiter the string is split and if your file names are consistent the following may help you.
Try Rearrange rule:
Rearrange: Split by delimiters " - ", " [", New pattern "$2 - $1 [$3" (skip extension)
Explanation:
Split by delimiters " - " and " [" gives us:
$1=Bobby Darin
$2=Splish Splash
$3=0-0-27-2].mp3
Then we use as New pattern
"$2 - $1 [$3"
Note that this rule will remove the delimiter we split on, so we have to add them to the "new pattern" too.
Additional tip: if you have more then one " - " pattern in your file name,
like f.ex. : Bobby Darin - Splish Splash [0 - 0-27-2].mp3
then you may use ""Split by exact pattern of delimiters"" which respects the order of occurrences of the delimiters.
HTH?
Maybe the wiki will show you some more:
http://www.den4b.com/wiki/ReNamer:Rules:Rearrange
http://www.den4b.com/wiki/ReNamer:Rules … e_Examples
(Thanks to the wiki maintainers)
Wow, that worked! I had to play with it a bit because of the quotation marks, but it works! I will really enjoy this. I've been looking for a way to do this for months now.. Thank you for your help and to the author of the software. A great solution!
Tim
