I'd like to know if it's possible to have ReNamer apply rules to files in a directory as normal, but have it ignore any files that meet certain criteria.
Right now, I'm having ReNamer insert the date meta tag to separate my files by date. I want to be able to have ReNamer ignore any files that have a date in the past in their filename, but rename any files that don't have a date stamp.
So if the date is 12/12/2010,
and I load C:\folder with these files into Renamer:
00A.file
12-10-2010_00A.file
Then ReNamer would rename the files like this:
12-12-2010_00A.file
12-10-2010_00A.file
Normally ReNamer would rename them like this:
12-12-2010_00A.file
12-12-201012-10-2010_00A.file
Can anyone please help me? Thanks so much!
From the examples you give, probably renamer would normally rename it with the underscore:
12-12-2010_12-10-2010_00A.file
In that case probably RegEx rule would be de most useful here.
From the name with that format (I mean with the underscore) we can remove the new date (in front) and keep the previous one.
This would be the RegEx rule:
Expression: "^\d+-\d+-\d+_(\d+-\d+-\d+_)"
Replace: "$1"
Actually, I want Renamer to do nothing to a file name if it detects a date string from yesterday or before in the file name. ReNamer should only perform operations on files that have not already been renamed.
