I'd like to create a ReNaming rule based on certain conditions. When I download Images and Movies from my camera into the same folder I use ReNamer to change the FileName. I have to run it twice because I use the [DatePictureTaken] to use on the Images but have to use the DateModified for Videos because there isn't the EXIF field of [DatePictureTaken] for the video clips. Is there a simple bit of Pascal script I can use that basically checks for the existence of the EXIF data and if it's not there then uses the DateModified instead. If there's a cleaner way of doing this I'd be keen to learn how to achieve this.
Many Thanks.
SJV
I guess you can use CalculateMetaTag() and check if the return value for a particular tag is null/empty. If so, use the other tag.
I have this for me, take a look at it, I think it might help.
Date: WideString;
Date := CalculateMetaTag(FilePath, 'EXIF_Date');
If (Date='') then Date := CalculateMetaTag(FilePath, 'File_DateModified');
FileName := '[' + Date + '] ' + FileName;
end.If this software has helped you, consider getting your pro version. :)
