Hi!..
(excuse my English)
I got this problem... I need rename a lot of images:
Files: final result:
I have created rules and I have this because the serialize rule dont have the option to reset the count each X numbers:
I tried to use PascalScript but Im not a programmer...
Please help me!! thanks a lot!!
rename the images manually mariconazo
The beta version has that option to reset at x numbers. You can find the beta on the download section.
Thanks!!!!!!!!!!!!!!!!!!!
