filename:=filepath+'\'+filename
this produces something like this c:\Pictures\family pics\nameofpicture.jpg\nameofpicture.jpg
how do u do this with out trying to create a directory with an ext. As far as I know you cannot create a directory with a extension in any operating system so why would doing this do exactly that.
I want to create a directory with the filename excluding the extension and copy serialized files into it. Can you help please
Lorne
You can add folders just inserting the name of the folder in front of the filename, the pascal is not needed.
I think you should try with: Insert ":File_BaseName:\" as Prefix
Thanks for the quick reply, useing "file_basename" makes a directory for each pic
I have pics named examplea1.jpg, examplea2.jpg, examplea3.jpg, and exampleb1.jpg exampleb2.jpg etc (just examples) if i use file_basename each file gets a different folder. I want to put the examplea*.jpg's in 'examplea' folder and the exampleb*jpg's in the exampleb folder etc. as I have allot of family pics and would like to reduce the time it takes to load the base directories. I found a script and after hours of trial and error came up with this.
BaseName, PathName, ExetName: WideString;
ExetName := WideExtractFileExt(FileName);
PathName := WideExtractFilePath(FilePath);
Filename := PathName+BaseName+'\'+BaseName+ExetName;
No need to apologize for your english and thanks again for the help
Hi!
For the purpose stated, you can simply use the $0\$0 token in normal rules. No pascal needed at all.
See help here: http://www.den4b.com/wiki/ReNamer:Renam … her_folder
