i need a regex rule to make
Led_Zeppelin-Ramble_On.mp3
to
led zeppelin - ramble on.mp3
Tyvm
No need for RegEx.
You can do it with this rules:
1) Replace: Replace all "_" with " " (skip extension)
2) Replace: Replace all "-" with " - " (skip extension)
3) Case: All lower case (skip extension)
Ty but with the second rule files already renamed correctly will be renamed again for the worse
uhmmm...
maybe this way...
1) Replace: Replace all "-" with " - " (skip extension)
2) CleanUp: Replace with spaces "_" and Fix spaces
