#1 2013-04-12 19:54
war59312
Buy Page Has Invalid XHTML
Looks like you pride yourself on valid xhtml code. smile
You should fix your buy page then:
hxxp://validator.w3.org/check?uri=http://www.den4b.com/?x=buy
cya,
Will
#2 2013-04-12 20:40
Re: Buy Page Has Invalid XHTML
Well spotted, thanks.
The "maxlength" attribute in the "textarea" tag is causing the validation error, it is an invalid attribute in XHTML even tho it is supported by most browsers and valid in HTML5.
Anyway, this page will be replaced soon and validation error will be no more.
