#1 2013-05-09 02:49
eR@SeR
Rename files with specific extension same as provided one
Well, situation is next. Have main folder called "Movies". In it folders with Movie names.
Structure is like this:
D:\Movies\Moviename\Moviename.avi
D:\Movies\Moviename\Moviename.srt
D:\Movies\Moviename\CouldBeMoreFiles...
I want to rename all subtitle files (extension are .ass .srt .ssa .sub .txt) same as video file (extensions are .asf .avi .flv .mp4 .mkv .mp(e)g .wmv) in that folder so I can play subtitles on any device. Most of them/all requires same video/subtitle filename in order to be displayed.
Example:
D:\Movies\Green Zone [2010]\Green.Zone[2010]DvDrip-aXXo.avi
D:\Movies\Green Zone [2010]\Green Zone.srt
D:\Movies\Green Zone [2010]\green.zone-aXXo.nfo
to be...
D:\Movies\Green Zone [2010]\Green.Zone[2010]DvDrip-aXXo.srt
I would like it if script could be used for other extensions, just rename/replace original and resulting ones. If I missed something to mention, ask.
Thanks! smile
#2 2013-05-09 16:53
Re: Rename files with specific extension same as provided one
You mean there could be only one "video file (extensions are .asf .avi .flv .mp4 .mkv .mp(e)g .wmv)" in a folder
but any amount of "subtitle files (extension are .ass .srt .ssa .sub .txt)" ?
So the rule is:
Step 1
- enumerate all files from a folder
- find the "video file"
- take the name part of that "video file"
Step 2
- work on the "subtitle files"
- rename them with that video file base name, leaving original extension
?yes?
At the moment I can think of such workflow:
Step 1 - PS-Rule1
- store it somehow to a var or file or clipboard (http://www.den4b.com/forum/viewtopic.php?id=1754)
Step 2 - PS-Rule2
- get the content of the var or file or clipboard
(Or merged to single rule which you have to execute twice,.... I don' know at the moment if we could use a kind of "Initial procedure" to do this work for us?)
666 ^^
#3 2013-05-13 02:23
eR@SeR
So the rule is:
Step 1
Step 2
?yes?
Actually there could be 2 video files (for example movie have cd1 or cd2) so there are 2 subtitle files for both videos. In other cases 1 video file is with 1 subtitle file,...BUT it could be 2 or rarely 3 subtitle files as alternative in folder. And yes, that kind of procedure (step 1/step 2) just with this:
- if there are 2 or more same extensions fix conflicting new names
So are you telling me that we cannot do anything about this? roll
Thanx for effort smile
#4 2013-05-14 07:40
Does this do more or less what you wanted?
It takes the name of the first video it finds, probably that should be enough. But if not, we can make it give a warning or something.
  BrotherFiles: TStringsArray;
  BasePath: WideString;
  I: Integer;
  if (Length(SubMatchesRegEx(FileName, '\.(ASS|SRT|SSA|SUB|TXT)$', False)) > 0) then
    BasePath := WideExtractFilePath(FilePath);
    SetLength(BrotherFiles, 0);
    WideScanDirForFiles(BasePath, BrotherFiles, False, False, False, '*');
    For I:=0 to Length(BrotherFiles)-1 do
      if (Length(SubMatchesRegEx(BrotherFiles[i], '\.(ASF|AVI|FLV|MP4|MKV|MPE?G|WMV)$', False)) > 0) then
        FileName := WideExtractBaseName(BrotherFiles[i]) + WideExtractFileExt(FileName);
        Break;
#5 2013-05-16 04:29
eR@SeR
Just as you said more or less it's doing. There are titles that have more info than video files so I've switched extensions in PS and works smile
Enough for many examples smile But... Try to handle these situations:
D:\Movies\King Kong [2005]\King Kong CD1 (2005)(1).srt
D:\Movies\King Kong [2005]\King Kong CD1 (2005).srt
D:\Movies\King Kong [2005]\King Kong CD2 (2005)(1).srt
D:\Movies\King Kong [2005]\King Kong CD2 (2005).srt
D:\Movies\King Kong [2005]\king-kong-2005-aXXo.nfo
D:\Movies\King Kong [2005]\King.Kong[2005]DvDrip.AC3[Eng]CD1-aXXo.avi
D:\Movies\King Kong [2005]\King.Kong[2005]DvDrip.AC3[Eng]CD2-aXXo.avi
D:\Movies\One Day 2011\1-3-3-8.com_l-oneday.xvid.cd2.avi
D:\Movies\One Day 2011\l-oneday.xvid.cd1.srt
D:\Movies\One Day 2011\l-oneday.xvid.cd2.srt
D:\Movies\One Day 2011\One Day 2011 BRRip XVID AbSurdiTy.avi
D:\Movies\The Manchurian Candidate\dmt-mancan-cd1.avi
D:\Movies\The Manchurian Candidate\dmt-mancan-cd1_SRPSKI_Duke2.srt
D:\Movies\The Manchurian Candidate\dmt-mancan-cd2.avi
D:\Movies\The Manchurian Candidate\dmt-mancan-cd2_SRPSKI_Duke2.srt
becomes
D:\Movies\King Kong [2005]\King.Kong[2005]DvDrip.AC3[Eng]CD1-aXXo.srt
D:\Movies\One Day 2011\1-3-3-8.com_l-oneday.xvid.cd2.srt
(duplicate)
D:\Movies\The Manchurian Candidate\dmt-mancan-cd1.srt
D:\Movies\The Manchurian Candidate\dmt-mancan-cd1.srt (should be cd2!)
So if you can, try to modify script to handle occurrences with cd1 or cd2 to replace them properly.
Note: In 2nd folder 2nd video file don't have cd1 as it should so if you cannot made to correct itself never mind, it's only one occurrence.
Note2: If there are duplicates as in 1st folder "Fix conflicting new names" is used.
D:\Movies\Friends 5\Friends_S5_01.avi
D:\Movies\Friends 5\Friends_S5_01.srt
D:\Movies\Friends 5\Friends_S5_02.avi
D:\Movies\Friends 5\Friends_S5_02.srt
D:\Movies\Friends 5\Friends_S5_03.avi
D:\Movies\Friends 5\Friends_S5_03.srt
D:\Movies\Friends 5\Friends_S5_04.avi
D:\Movies\Friends 5\Friends_S5_04.srt
becomes
If video and title are same ignore replacing.
I think that's it. Thanx again, you saved me a lots of renaming wink
#6 2013-05-16 09:08
That is getting complex, I think is better to keep it simple...
Why not this?...
You add every file to renamer, and you sort the files first one video then it's subtitle, and so on.
And then with this script you put the name of the last video on the next file.
  BasePath, LastPath, LastName: WideString;
  BasePath := WideExtractFilePath(FileName);
  if (Length(SubMatchesRegEx(FileName, '\.(ASF|AVI|FLV|MP4|MKV|MPE?G|WMV)$', False)) > 0) then
    LastName := FileName;
    LastPath := BasePath;
  end
  else
    if (BasePath <> LastPath) then
      LastName := '';
    if (LastName <> '') then
      FileName := WideStripExtension(LastName) + WideExtractFileExt(FileName);
      LastName := '';
    end
    else
      FileName := '';
If you don't like the order, reorder it (Ctrl+Arrow) and preview again.
It's a little bit more work but it gives more awareness of what is changing, and I don't think that can be bad...
#7 2013-05-16 15:11
eR@SeR
In my case it's lots of work sad It renames every file below video file no matter of extension (except video ext) and that is what we want to evade.
becomes
D:\Movies\King Kong [2005]\King Kong CD1 (2005).srt (ignored - should be as upper result)
D:\Movies\King Kong [2005]\King.Kong[2005]DvDrip.AC3[Eng]CD2-aXXo.srt
D:\Movies\King Kong [2005]\King Kong CD2 (2005).srt (ignored - should be as upper result)
Have to repeat/add files again sad
With modified:
becomes
No matter of the order and thinking what and where to put. The simplest solution, don't you think?
First script is very good, I just suggested what criteria to add to make it even better to handle more things without changing the intended result, but if that cannot be modified than I'll use last PS.
#8 2013-05-16 16:46
What problem do you see in the last script? not avoiding non subtitle extensions? It can be added.
I made the script clear the last name if it was already used, do you want to keep using it even if it creates duplicates?
Not so simple to code...
Now, I tried to fix the previous one, and this is what came up: (I don't think I can get much better than this...)
  BrotherFiles, VidFiles: TStringsArray;
  BasePath, RExVid, RExSub: WideString;
  I: Integer;
  Found: Boolean;
    SetLength(VidFiles, 0);
        SetLength(VidFiles, Length(VidFiles)+1);
        VidFiles[Length(VidFiles)-1] := WideExtractBaseName(BrotherFiles[i]);
    if (Length(VidFiles) > 0) then
      if (Length(VidFiles) = 1) then
        FileName := VidFiles[0] + WideExtractFileExt(FileName);
      end
      else
        RExSub := ReplaceRegEx(FileName, '^.*?((\b|_)(CD\d+)(\b|_)).*?$', '$3', False, True);
        if (RExSub <> '') then
          Found := False;
          For I:=0 to Length(VidFiles)-1 do begin
            RExVid := ReplaceRegEx(VidFiles[i], '^.*?((\b|_)(CD\d+)(\b|_)).*?$', '$3', False, True);
            if WideSameText(RExVid, RExSub) then
              Found := True;
              FileName := VidFiles[i] + WideExtractFileExt(FileName);
              Break
          if (not Found) then
            FileName := '';
    end
    else
      FileName := '';
#9 2013-05-17 02:03
eR@SeR
You already done it big_smile
What I've asked, you made it. Works almost perfect for every occurred scenario! Thanx! smile
This was ignored only:
D:\Movies\Casshern\Cassherncd1 Srp.srt
D:\Movies\Casshern\Cassherncd1.avi
D:\Movies\Casshern\Cassherncd2 Srp.srt
D:\Movies\Casshern\Cassherncd2.avi
...but never mind.
So, script finds video files (.asf .avi .flv .mp4 .mkv .mp(e)g .wmv) and renames corresponding subtitle files (.ass .srt .ssa .sub .txt) as video basenames. Also do:
- skips renaming of same basenames
- finds cd(digit) in filename and renames corresponding files containing cd(digit) [case insensitive]
- if there is surplus of subtitle file(s) in same folder it will be renamed as 1st one (must use "Fix conflicting new names")
Note: *.txt don't have to be subtitle file so be careful!
  I: Integer;
  Found: Boolean;
      end
      else
          Found := False;
              Found := True;
              Break
          if (not Found) then
            FileName := '';
    end
    else
      FileName := '';
