#1 2013-09-30 01:42
Enrico65
RegExp and \u \U \l \L...
Dear Denis, many thanks for your exceptionally good renaming software, which keeps on improving year after year!
I bring once again to your attention the noticeable limits of the RegExp engine used in ReNamer.
The absence of \u \U \l \L support (among some other RegExp features) creates quite frequent problems when filtering the filenames, in cases in which the CASE function is not subtle enough to provide the required power.
The presence of the Case-sensitive checkbox helps, but cannot replace in full the lacking filters.
I know that we can face every situation with a Pascal script, but, well...
It is my understanding that introducing a wider RegExp engine might be complex at this stage.
The alternative might be to further improve the power of the CASE rule, introducing some of the features available in the DELETE and in the REPLACE functions, such as:
From-until
Position, delimiter, count
Interpret ?,*,[, .... as wildcards
etc.
Most cordial regards,
        Enrico.
#2 2013-09-30 22:17
Re: RegExp and \u \U \l \L...
Hi Enrico,
Yes, replacing RegEx engine is something I would try to stay away from unless it would be absolutely necessary.
By the way, a similar idea of extending the functionality of the Case rule has been discussed recently and it looks like a viable option.
#3 2013-10-01 00:16
Enrico65
Hi Denis
    and thanks for your prompt reply.
I overlooked the post about extending the power of the CASE rule.
I strongly hope it will be placed in the future ReNamer releases.
Once again, thanks and most cordial regards,
        Enrico.
#4 2013-10-01 10:55
Recently I found out that Free Pascal component library uses the same RegEx engine (regexpr.pas) as in ReNamer, except it is slightly modified version to add support for \u \U \l \L flags.
So I got an idea of trying an adaptation of this updated engine and with some minor modifications I was able to integrate it into ReNamer. Preliminary tests show great results, we now have working \u \U \l \L flags. However, this library requires further compatibility testing before it can be used in the mainstream.
I have put together an experimental version of ReNamer for testing:
ReNamer-5.72.4-RegEx-Updated.zip
Please test this version for the following:
* It must behave identically to latest stable release, test against all your RegEx rules.
* Correct behaviour of \u \U \l \L flags.
#5 2013-10-01 12:15
Great news. Thank you very much.
I guess this should work like:
Changing case in the 'Replace' box of regular expressions rule
Special character          Description
\u                                Converts the next character to uppercase.
\l                                 Converts the next character to lowercase.
\U                                Converts all characters to uppercase until encountering \E.
\L                                Converts all characters to lowercase until encountering \E.
\E                                End \U or \L.
Test 1
Lou Bega - Mambo Nr 5.mp3
ReNamer-5.72.4-RegEx-UPDATED.zip
Lou Bega - MAMBO NR 5.mp3
USE:
1) RegEx: Replace expression "(.+)-(.+)" with "$1-\U$2" (skip extension)
Test 2
of ReNamer
your RegEx
Free Pascal
Free PASCAL
of reNamer
your regEx
Free pascal
Free pASCAL
USE:
1) RegEx: Replace expression "(.+) (.+)" with "$1 \l$2" (skip extension)
Test 3
Preliminary tests
show great results
we now have working
Preliminary TESts
show great RESults
we now have WORking
USE:
1) RegEx: Replace expression "(.+) (.{3})(.+)" with "$1 \U$2$3" (skip extension)
Test 4
Preliminary tests - SHOW great results
we NOW Have - Working Flags
To:
Preliminary tests - SHOW GREAT RESULTS
We now have - WORKING FLAGS
USE:
1) RegEx: Replace expression "(.)(.+) - (.+)" with "\U$1\L$2 - \U$3" (skip extension)
Works in preview on W764
#6 2013-10-01 19:23
Second test works too on W732
http://www.den4b.com/forum/viewtopic.php?id=1812
BEFORE:
titles title S01E01.ext
Titles s08e20.ext
AFTER:
Titles Titles S01E01.ext
Titles S08E20.ext
USE RULES:
1) Case: Capitalize every word (skip extension)
2) RegEx: Replace expression "s(\d\d)e(\d\d)" with "S$1E$2" (skip extension)
http://www.den4b.com/forum/viewtopic.php?id=1790
James_Band_007_Der_Abend_stirbt_nie_1_1.03.29_20-15_atv_140_TVOF_XX.mpg.avi
James_Band_007_Der_Abend_stirbt_nie_2_13.03.29_20-15_atv_140_TVOF_XX.mpg.avi
James Band 007 Der Abend stirbt nie 1.avi
James Band 007 Der Abend stirbt nie 2.avi
USE:
1) RegEx: Replace expression "_\d{1,2}\..+" with "" (skip extension)
2) Replace: Replace all "_" with " " (skip extension)
http://www.den4b.com/forum/viewtopic.php?id=1783
File 01 (720p).mp4
File name 03 (720p).mp4
File name extra 23 05 (720p) 45 text.mp4
File (720p) 01.mp4
File name (720p) 03.mp4
File name extra 23 (720p) 05 45 text.mp4
USE:
1) RegEx Rule: Replace expression "^(.+)(...)( \(720p\))(.+)?$" with "$1$3$2$4" (skip
extension)
http://www.den4b.com/forum/viewtopic.php?id=1767
USE:
1) RegEx: Replace expression "\A(\d\d-)" with "wood-$1" (skip extension)
http://www.den4b.com/forum/viewtopic.php?id=1758
Stargate701
Stargate DVDrip 702
Stargate 123 DVDrip 703
Stargate7x01
Stargate DVDrip 7x02
Stargate 123 DVDrip 7x03
USE:
1) RegEx Rule: Replace expression "(\d)(\d\d)$" with "$1x$2" (skip extension)
http://www.den4b.com/forum/viewtopic.php?id=1180
Ace of Base - everytime it rains - [ACECD 10] - [2000]
Ace Of Base - Everytime It Rains - [ACECD 10] - [2000]
USE:
2) RegEx: Replace expression "(\[.+])" with "\U$1" (skip extension)
http://www.den4b.com/forum/viewtopic.php?pid=5798#p5798
John Doe - Text File, The
John Doe - Text File, A
John Doe - Ideal Text File, An
John Doe - The Text file
John Doe - A Text File
John Doe - An Ideal Text File
USE:
1) RegEx: Replace expression " - ([^-]+), (\w+)$" with " - $2 $1" (skip extension)
http://www.den4b.com/forum/viewtopic.php?id=1157
Sway - Silver And Gold (Feat Akon)
Fat Joe - Make It Rain (Feat Lil Wayne)
Lil Jon And The East Side Boyz - Snap Yo Fingers (Feat Sean Paul)
Sway (Feat Akon) - Silver And Gold
Fat Joe (Feat Lil Wayne) - Make It Rain
Lil Jon And The East Side Boyz (Feat Sean Paul) - Snap Yo Fingers
USE:
1) RegEx: Replace expression "^(.*?) - (.*)(\(.*?\))$" with "$1 $3 - $2" (skip extension)
#7 2013-10-01 23:10
@Stefan Thanks for all the testing!
It looks like it's working as expected and should be ready for Beta release.
#8 2013-10-02 00:17
Enrico65
Dear Sirs, you know? You are GREAT!
Thanks and most cordial regards,
        Enrico.
#9 2013-10-02 07:41
Changing case of the next "part" in the 'Replace' box of regular expressions rule.
A "part" could be just the next literal char, but it makes much more sense working on a backreferences.
A backreference you can capture by using parentheses "(...)" around your regular expression
in the Expression box and refer to this with the "$n" statement in the replace box.
To change the case you can utilize this four modifiers:
\L                        Convert all following characters to lowercase
\l                        Convert the next character to lowercase.  (that's a lower case L)
\U                        Convert all characters to uppercase
\u                        Convert the next character to uppercase.
This can be used like in this examples:
\L      Converts ALL following characterS to lowercase
TO:        into renamer
USE:    RegEx: Replace expression "(.+) (.+)" with "$1 \L$2" (skip extension)
\l      Converts the NEXT character to lowercase.
TO:        into reNamer
USE:    RegEx: Replace expression "(.+) (.+)" with "$1 \l$2" (skip extension)
\U      Converts ALL following characterS to uppercase
TO:        INTO reNamer
USE:    RegEx: Replace expression "(.+) (.+)" with "\U$1 $2" (skip extension)
\u      Converts the NEXT character to uppercase
TO:        Into reNamer
USE:    RegEx: Replace expression "(.+) (.+)" with "\u$1 $2" (skip extension)
Some Testing:
Convert the last three chars to upper:
TO:        into reNaMER
USE:    RegEx: Replace expression "(.+)(.{3})" with "$1\U$2" (skip extension)
Convert the next literal character (makes not really that much sense)
TO:        into ReNamer Universe
USE:    RegEx: Replace expression "(.+) (.+)" with "$1 $2 \Uuniverse" (skip extension)
Convert the third char to lower:
ReNamer
UmBenenner
NеPеименовать
Renamer
Umbenenner
Nеpеименовать
USE:    RegEx: Replace expression "(..)(.)(.+)" with "$1\l$2$3" (skip extension)
Change case before/after a delimiter like here the hyphen:
boogie pimps - sunny.mp3
Grave Digger - Heavy Metal breakdown.mp3
BOOGIE PIMPS - Sunny.mp3
GRAVE DIGGER - Heavy Metal Breakdown.mp3
USE:
2) RegEx: Replace expression "(.+) - (.+)" with "\U$1 - $2" (skip extension)
Boogie Pimps - SUNNY.mp3
Grave Digger - HEAVY METAL BREAKDOWN.mp3
USE:
2) RegEx: Replace expression "(.+) - (.+)" with "$1 - \U$2" (skip extension)
Move to new created sub folder:
Anthrax - MadHouse.mp3
Black Sabbath - Paranoid.mp3
.\MADHOUSE\Anthrax - MadHouse.mp3
.\PARANOID\Black Sabbath - Paranoid.mp3
USE:
1) RegEx: Replace expression "(.+) - (.+)" with ".\\\U$2\\$0" (skip extension)
@Denis,
can you add more own code to provide a "\T"  Title modifier too, which call your "Capitalize Every Word" code?
And maybe, not necessary, but for even more convenient, a "\S" Sentence modifier to utilize "First letter capital"
deep purple - black night.mp3
axel rudi pell - nasty reputation (live).mp3
Deep Purple - BLACK NIGHT.mp3
Axel Rudi Pell - NASTY REPUTATION (LIVE).mp3
Use (proposal only):
"(.+) - (.+)" with "\T$1 - \U$2"
#10 2013-10-02 21:58
I could, but since it's a third party component I would want to keep the amount of custom changes to the minimum in order to make future upgrades easier.
Those additional modifiers could be simulated by combining both Case and RegEx rules.
