#1 2014-03-23 16:02
therube
Remember size of the main window
Remember Size
Like (& kind of alluded to) here, Let Hasher remember window size and position?
Position can now be set, but if you drag the window wider, that is not retained.
#2 2014-03-27 10:58
Re: Remember size of the main window
This option has been implemented in v3.0.0.2 Beta.
Both location and size are remembered. Once you enable the relevant option, you should see in Hasher.ini something like:
[Location]
MainForm=1,131,46,678,515
This set of numbers stands for: Remember (1 or 0), Left, Top, Width, Height.
#3 2014-03-30 17:12
therube
I see.
Guess I was expecting them to operate independently of one another.
Being able to set location, remembered, & then separately, size.
