#1 2014-03-23 16:53
therube
Log Viewer - select all entries, stick to main window, remember size
Log Viewer:
Was quasi "sticky" in 30alpha.
So it could be "stuck" to the bottom of the Hasher window & if you dragged the window, the log, attached would follow.
No big deal, but I feel it was a nice feature.
Control+A to select All.
As it is now, you can select multiple items, but Ctrl+A would be a convenience.
Should maintain its sizing on restart
#2 2014-03-27 21:52
Re: Log Viewer - select all entries, stick to main window, remember size
Yes, it was a nice feature, but I don't think it is very suited for the current log viewer. The old "log" window from the previous version is similar to the "messages" panel is the new version, which is combined into the main window.
Done, implemented in v3.0.0.3 Beta.
I will consider this.
