#1 2015-06-17 22:04
Shutter 3.7
This is a recommended maintenance update for Shutter.
Most notable improvements:
  • Added "Turn On" option to the Monitor action.
  • Recreate icon when taskbar is recreated (Explorer restarts).
  • Use newer shutdown/reboot API to capture more details in the system event log.
Full list of changes in Shutter 3.7:
* Recreate icon when taskbar is recreated (Explorer restarts);
* Cleanup tray icon code;
* Added uninstaller icon;
* Added "Turn On" option to the Monitor action;
* Code refactoring and cleanup of system shutdown/sleep procedures;
* Fixed potential issue with Logoff action on Windows 9x platforms;
* Use newer shutdown/reboot API on Windows XP and later to capture the name of application and a custom shutdown message in the system event log;
* Fixed incorrect status message of countdown event when 1BY1 logic is used;
