#1 2016-10-12 20:13
Lauraq
reverse name and surname
Sorry, another question smile
is possible inverse name and surname, for example, I have my file named like it:
Lorenzo Jovanotti - La gente della notte.mp3
I want
Jovanotti Lorenzo - La gente della notte.mp3
Thanks smile
#2 2016-10-13 09:55
#3 2016-10-13 10:49
Lauraq
Re: reverse name and surname
I have read your link but I havent' find a solution. The best that I have find is:
split using: Exact pattern
in the first space to write I have put only a space
in the second I have write $2
but, if my mp3 is named
the result is
the name is deleted sad
#4 2016-10-13 13:05
Have you looked at Example 1?
In your case it is best to use:
Split using: Exact pattern of delimiters
Delimiter: " - "  (without the quotes)
New pattern: $2 - $1
#5 2016-10-13 20:47
Lauraq
don't work sad  it rename in:
La gente della notte - Lorenzo Jovanotti.mp3
#6 2016-10-13 22:38
I have misread your question.
If you want to swap only the first two words, then use:
Delimiter: " | "  (without the quotes)
New pattern: $2 $1 $3
#7 2016-10-14 12:49
Lauraq
perfect! Thanks smile smile smile
