#1 2017-06-27 10:09
Promaster
Action task - send email
Hi Denis,
I got an suggestion for the next shutter version.
It is possible to set an new action task, to send an email when all events tickered?
So that I got an email, when my pc go to sleep, or when it wake up.
And if you like, i would translate shutter 3.8 to german, i see that only the older version 3.7 is in german available on your site.
#2 2017-06-29 11:51
Re: Action task - send email
Hello!
It is possible to set an new action task, to send an email when all events triggered?
Not at the moment, but this feature suggestion is on the list for implementation in future versions.
Yes, of course!
At the moment, Shutter is undergoing a major refactoring and migration to a newer development environment, which will allow a much easier localization (translation) via PO files. It will take another couple of months at least before it is ready, but if you wish you could create/improve German translation for other products which already support the new localization method.
