#1 2017-07-10 13:22
Stamimail
Suggestion| to set position or selection before applying action (rule)
There are many actions (rules) you want to apply only after you telling the program what position or what selection to apply.
Currently the program trying to set it for each rule.
I'm thinking about to find a way that the user set first in filenames:
Position
or
Selection
and then choose action (rule) to apply on:
Insert/Serialize...
Replace/Case...
#2 2026-06-03 14:04
Stamimail
Re: Suggestion| to set position or selection before applying action (rule)
I think that in your program it would be a Macro.
See how in Microsoft Word macros recording works.
In the same way, when the user is asked "where:",
when he choose a Macro option,
a dialog box is opened, something like a TextBox with all the filenames list, and a Record icon is flashing.
It will record the user keys (movements/selections) the same way user uses in Word or Notepad.
For Example:
End, Ctrl+LeftArrow, Ctrl+Shift+LeftArrow
When the user use DownArrow/UpArrow to move to next/prev filename,
the cursor jumps to the beginning of the line/filename and the recording start over.
When user move/select in one line, he will be able to see how it takes effect in other lines.
That means, in each line there is a cursor/selection,
so that the user's line is in one color, and the other lines are in different color.
#3 2026-06-12 09:02
Hopefully, this will materialize in something like a Select rule, which would allow selecting a part of the filename using a regular expression pattern (or a similar mechanism) and then applying the subsequent rules only to the selected part.
#4 2026-06-17 21:45
Stamimail
But the Macro trick is not only for a selection, but also for placing a cursor position.
