#1 2017-08-24 16:01
NexusFred
Serialize files in multiple subfolders in descending order
I try to use the serialize option but in descending order.
Folder
	SubFolder_01
		  Or. Name   > New Name
		File_A_0001 > File_A_0005
		File_A_0002 > File_A_0004
		File_A_0003 > File_A_0003
		File_A_0004 > File_A_0002
		File_A_0005 > File_A_0001
	SubFolder_02
		  Or. Name   > New Name
	SubFolder_03
		  Or. Name   > New Name
In the lite version I do not find a Ascending Descending Order option.
The name column do not respect the subfolder structure.
Best Regards
NexusFred
#2 2017-08-24 16:17
Re: Serialize files in multiple subfolders in descending order
To serialize in descending order, you simply specify a negative Step parameter, for example "-1". However, if you have different number of files per subfolder then you can't start at a fixed initial value.
Instead, why don't you sort in inverse order by Path column and then serialize in the usual ascending order with automatic resetting of the serialization index if folder changes, like shown below.
Note that I have prefixed new names with "_" to avoid conflicting new names. You can remove it in a second pass.
#3 2017-08-24 19:04
NexusFred
Thanks !!
A  negative Step parameter do not work, the result is
File_A_0001 > File_A_-0001
But order by Path column work well. big_smile
Thanks a lot.
#4 2017-08-24 22:14
For a negative step to work as you expect, you need to change the "Index starts" option to a higher number, for example "5" if you have exactly 5 files in a folder. So it would go from 5 down to 1 in steps of -1. But this would be useful only if you have a fixed number of files in each subfolder. Otherwise the reverse sorting by Path column would work best.
