#1 2017-11-07 23:21
Dirk
Show the time an event happens instead of showing the countdown?
Could Shutter show the time an event happens instead of showing the countdown:
#2 2017-11-20 09:48
Re: Show the time an event happens instead of showing the countdown?
This could be implemented as an option, to show event configuration rather than the status.
#3 2017-11-20 10:52
Dirk
That would be great. Many thanks!
If in the icon (in the tray) could be shown the time of the event it would be great also (so without (inter)action needed to show the time). But I assume to create such would be quite laborious.
#4 2018-01-08 12:53
Shutter 4.1.0.2 Beta:
* Added options to toggle event details and status in the tray icon hint.
#5 2018-01-08 13:31
Dirk
Thank you very much!
#6 2018-01-08 13:45
Dirk
It looks like that:
The "Uhrzeit" is the start of the event and not the time now, I assume.
#7 2018-01-08 14:18
The new settings can be found in the Advanced Options window:
Not sure what you mean.
P.S. The German translation is quite incomplete and outdated. Would you be interested in updating the translation file?
#8 2018-01-08 14:39
Dirk
Ah yes, the new settings, many thanks!
Now I see, it is the starting time of the event.
Actually I would be rather not, but if it would help, I would do it of course. I use the english version, but the German one looks quite good, besides of the none fitting text on the buttons.
