#1 2018-02-15 15:23
miserable
Description of "Hook" methods for "User Inactive" event
Could you please explain a bit how the "Low Level Hook" and "Injection Hook" methods work, and what the implications of using them are? The documentation currently does not mention these.
#2 2018-02-16 23:07
Re: Description of "Hook" methods for "User Inactive" event
The methods for monitoring user inactivity are now described on the wiki:
http://www.den4b.com/wiki/Shutter:Events
  1. Last Input Event - Uses GetLastInputInfo API. Captures activity only of the initiating user session. The most stable and the least intrusive approach.
  2. Low Level Hook - Uses SetWindowsHookEx(WH_KEYBOARD_LL) and SetWindowsHookEx(WH_MOUSE_LL) API. Captures activity from all user sessions. Applied without injection into foreign processes to achieve a less intrusive effect, contrary to the official documentation, so it may stop working in future versions of Windows.
  3. Injection Hook - Uses SetWindowsHookEx(WH_KEYBOARD) and SetWindowsHookEx(WH_MOUSE) API. Captures activity from all user sessions. A tiny dedicated library file is injected into all foreign processes to capture user activity across all applications. This is a well established approach which may yield better results in some cases, but it is the most intrusive approach.
