#1 2006-06-21 17:12
dieten
Disable cancel button in confirmation
Is there a way to disable or remove the cancel button when the alert message shows?  I would like to prevent the user from stopping the event.
If not, is there a way to automatically restart the event after the user clicks on cancel?
Eric
#2 2006-06-22 12:02
Re: Disable cancel button in confirmation
Hi Eric smile
No, unfortunately there is no way to disable the cancel button in that message.. Unless I add this functionality.
You can do that, just don't use the Shutdown Message, and use an options called "Never show Tray Icon". So once the Shutter is started and minimized - there is no way a user can cancel it (except terminating the process via Windows Task Manager).
No, thats how cancel button is intended to work...
The solution below the second quote - will it help you?
