#1 2020-02-11 19:14
Bullone
Backup configuration and rule
I've enabled the option to start automatically Shutter app and it works fine but I'd like also to apply the same settings and rule/actions in all my PC users... is it possible?
#2 2020-02-12 11:48
Re: Backup configuration and rule
Yes, you can copy the configuration and the presets to other computers.
If you use the installer version, then you can find the settings and the presets in your user profile directory:
%USERPROFILE%\Documents\den4b\Shutter
If you use the portable version, then both the settings and the presets are stored in the same directory as the executable file.
#3 2020-02-12 12:57
Bullone
Oh thanks!
